Hi, I'm having trouble with my EasyTouch system and pool pump, (pentair superflo VS). The pump is not turning on the at the scheduled time, and I have to manually turn the pool pump on using the panel on the pump itself. Also, the pool cleaner booster pump is coming on when the pump is not running. The easytouch is set to "Auto" on the main screen, and the time is correct. My pool was built at the end of summer, and when they finished it was programmed and the pump and pool cleaner worked fine. Any suggestions? Thanks!!
