That was a new word I had to look up. No, it wasn't from here that I heard it. Ok, that helps a lot. Thanks.Where did you read that? Certainly not here
Chlorine has nothing to do with turbidity and it will not directly cause turbidity.
Test | 2017-02-06 6:00 PM | 2017-02-07 9:00 AM |
Free Chlorine (ppm) | 12.0 | 5.0 |
Combined Chlorine (ppm) | 0.0 | 0.6 |
pH | 7.4 | 7.4 |
Total Alkalinity (ppm) | 60 | 60 |
Calcium Hardness (ppm) | 180 | 170 |
Cyanuric Acid (ppm) | 35 | 35 |
Sodium Chloride (Salt, ppm) | 2000 | 2000 |
SWG Instant Salt (ppm) | 2000 | 2000 |
Temperature (F) | 59 | 58 |
pH to 7.0
Read the thread for reference. This was the consensus recommendation and it worked. In any case, I'm not concerned about how to do the SLAM. I have that covered and was very successful with it last time.Why? pH and TA look fine.
Good one!! :eye:It's called forensic pool chemistry.
I would have thought that'd be the case. I have the measurement from last night (three days into the current storm) and the measurement from this morning. Don't exactly know why the FC dropped so quickly.1. A single rain storm should not be able to cause a pool to go green if the proper FC/CYA ratio is maintained both before and during the storm. While I agree that storms can blow junk into your pool, the chlorine present is more than adequate to handle to load. Even a few inches of rainwater typically only represents a few % change in total pool volume and so the dilution will be minimal.
Yes, that is correct. It's never been an issue before. It maintains FC just fine when it's on. I don't even run the SWG in the winter because of the low temp.2. Are you really running a T-9 cell on a 22,000 gallon pool?
There absolutely are dead spots in it. I brush them daily, though.3. Your pool has a unique shape to it and I'm wondering if you have circulation dead spots in the pool that allows for the depletion of FC in those areas even though your testing might show proper FC levels in the bulk of the pool water.
Last week was the last time is was cleaned. A month ago when I did the original SLAM, I was cleaning it every day. As for the run off, yes, I do notice outside runoff getting into the pool when it pours like it did last night.4. When was the last time you opened the filter and cleaned it? Is there any surface water runoff getting into the pool?
Ok. I'll need to figure out a countermeasure for this. It seems strange that the pool and landscape designers didn't think of proper drainage for something like this. The pool and new landscaping is literally five months old and I've already had to SLAM twice due to what we think may be the same problem. Is this something I should call them out on to address?Yep, stop the runoff if it has dirt, dust, soil, anything whatsoever in it. Otherwise you're fighting a losing battle.
Yeah, it was very clear there were these dead spots you were talking about from the first week of me taking care of it. I've been very proactive in addressing it manually. Unfortunately, they're in places that are out of reach for the cleaner. That was an adventure in itself and I'll give ya the very quick story on it.Good work to be brushing those dead spots every day!! Does the cleaner get to them? That will help refresh chlorine at the boundary between water and plaster as well. So much better when it's constantly refreshed by water movement, but you're sure putting the effort in, well done.
