Hi,
I currently have a compupool compuchlor deluxe self cleaning salt generator with an A200 cell attached producing 20gr/hr of chlorine. The cell is broken, and I've just replaced it with an A300 cell.
From what I've read online it is often a good idea to upsize to a bigger size cell and turn down the chlorine production if required. I tried to contact Compupool to confirm this, but unfortunately they are not responsive and after leaving multiple messages and emails, they have not yet replied.
My chlorine generator unit has a sticker saying;
Input:
220/240VAC,
50/60HZ
9amps
Ouput:
8.5V DC
20 Amps
I assume there is a transformer or something converting the AC to DC at the electrical unit for the salt cell.
I have attached the A300 cell, and had it running on high for a couple of days, everything appeared well until this morning when it was reading '0' chlorine on the output dial. It appears one of the connections where the electrical unit and salt cell wire connect at has burned/melted. It was fixed to the connector with a screw, with a wire from the power unit and cell meeting in the middle of the connector
My question is , have i sourced a cell with too high a current rating for the generator unit, or is the burning likely down to a poorly connected wire that generated heat. I.e If i turn my chlorine dial up, does this increase the required current being pulled from the power unit to the chlorinator and hence cause the burning issue, or is it simply likely to be just a bad connection between the wires?
The specs for the A200 say 200ml chlorine/hr with 240w/1amp running costs, the A300 cell say 300ml chlorine 320W/1.2amp running costs.
I've seen other specs for this cell from alternative suppliers which says 30amp for A300, 20amp for A200. Not really sure what this current value refers to and why it is different from the 1amp or 1.2amp listed above?
Appreciate any help
Input:
220/240VAC,
50/60HZ
9amps
Ouput:
8.5V DC
20 Amps
Appreciate any help
