I just recently replaced my Hayward Superpump II 2HP with an Intelliflow VS Pump. After replacing it and starting it up, I notice that my pump never seems to fully prime although the pump drops out of prime mode and runs fine. When turning on my Polaris it won't run properly. It seems as it is not getting enough water pressure. It jerks back and forth and barely moves. As a test, I switched my valve to my hot tub for intake and the pump fully primed and the Polaris runs normal. Here is the dig - my pool returns are plumbed with 1 1/2" and the hot tub is plumbed with 2". One thing I did different this time is that I had to replace my Jandy Valves which were 1 1/2" (hot tub return was coupled down) to 2" so I stepped up the pool returns. I thought this would be more efficient but maybe I am wrong? I will also note that there is more length from hot tub return to last valve than there is from the pool valve to the last valve - at the pump.
Pic is before pump was replaced but basically the same.
Any ideas?
Any ideas?
