Sorry to be making my first post a request instead of a contribution. I've been lurking and learning so much here for a while - thanks for the great forum. The pool in question (details in the signature) gets re-filled with well water that has a CH of around 220.
Here's the problem. A few weeks ago I noticed a slight cloudiness and it got to where I could barely see the bottom within a few days. There has never been a green color, CC has always been zero and the overnight chlorine loss test has never shown a change. It seems like algae isn’t the problem but I put some extra chlorine in at first just in case. I attached a picture of the water today.
With the help of this forum I’ve been keeping the water chemistry in line pretty well, at least I thought. It has been a couple years without any kind of trouble at all. The only thing worth noting is the pool seems to very regularly need acid to keep the PH down. Here are the current numbers:
FC 12
CC 0
PH 7.3
TA 70
CH 650
CYA 40
The filter has been running about 12 hrs per day since this started and only just now they need a cleaning, which I will do within the next couple days.
I know the CH is a bit high but, from reading here, I was under the impression it can be managed up to 900+.
Any thoughts? Thanks very much for any help.
FC 12
CC 0
PH 7.3
TA 70
CH 650
CYA 40
