Here is a diagram I've drawn of my pool plumbing.
The circles represent a 2 and 3 way valve. The 3 way value is the one near the gas heater and the other two near the solar are 2 way valves. I've drawn a circle under the 3 way value indicating at what position it's closed. I haven't touched that position since the guy came out to fix my gas heater. I'm not sure which pipe is the inlet to the gas heater.
Even though the solar inlet and outlet run off same pipe I'm assuming the water will only run one way due to the pump pulling the water. Does the plumbing look dodgy near the gas heating? What stops the water flowing to both the input and output of gas heater? And what stops the water coming from the solar flowing back to solar or to gas heater? Should the 3 way valve be fully closing one of the pipes?
