I've been lurking on TFP for a while since we built our pool last year and this is the first time posting here. Everyone here is super helpful and I've learned a lot, thanks.
So, last year contractor closed the pool for me. I'm a bit nervous but think I'm up to doing it myself this year, just looking for some advice in a couple of areas:
1) Water has been great all season, and well balanced. Now, just before close, noticed some new fringe numbers for TA, CH, CYA:
FC=2.4
CC=0.2
pH=7.4
TA=80
CH=400-420 (fading endpoint on test)
CYA>/=100
water temp= 46'
I just got rid of pool service a couple of months ago, they were just shocking every week and FC would always be sky-high 10ppm for several days. So, I was excited about getting it right with trichlor feeder and no liquid Cl, so thinking I probably drove down TA a bit and jacked-up CYA. I read other posts about this effect and now think I understand my mistake with tabs. I want to close next couple days before freeze and actually blew out some of the lines today with intent to try to get it done tomorrow, but that was before final check of CYA. Am I right about this and now what should I do? I'd really like to just close it, and will open super-early before temps get warm (like early April) so I wonder if I can drain it well below returns mix some more Cl in using utility pump (how much? CYA level? Water is already cold...) and strap on the loop-loc and let the rain/snow dilute things (last year I had to pump several inches out multiple times to keep water off top step to avoid freeze damage to plaster.)
2) What's the recommended antifreeze dose? I have double drain, two skimmers, four returns: should I put a gallon in each and plug, or do I need to try to fill the lines completely? At the equipment pad, do I need to try to put some into drain and skimmer suction lines at the pump? Finally, heater and pump just get drained, no antifreeze in there right? Freezing pipe in concrete pool wall is a scary thought, so I just want to make sure I'm doing this right.
Thanks again for the advice. Hope I can payback some day when I get more confident.
FC=2.4
CC=0.2
pH=7.4
TA=80
CYA>/=100
water temp= 46'
