Hi all!
im a new owner of an existing pool. I think I've learned a lot over the past few weeks. I've replaced the air relief assembly on my filter, I've rebuilt the intervals of my jandy caretaker, I've even found and patched a leak around the skimmer.
So when I noticed that the solar was leaking from a badly repaired elbow joint on the side up to the top of the panels "no problem" I think to myself. I'll get sone 2" pvc bits and make a fix myself.
(I should point out I just want to get through the winter, the house will need a new roof soon so the plan was to do that in the spring when I no longer need solar and get new solar next fall)
After removing cutting the bad elbow out I deiscover it's not 2" pipe. It's something else. It's black 'pvc-1' pipe but it's just slightly bigger than 2".
So my question is: does anyone know what size it might be and where I can source the parts to patch in a new elbow?
Thanks!
Thanks!
