Thanks, and I do hope you are fully enjoying your tub.
I use a SWCG, and have not had trouble balancing the water - ie other than the initial learning curve!
I did run a SLAM in the middle of August. After 3 days of keeping FC levels up:
For the OCLT: the FC went from 12 ppm to 11ppm, so a drop of 1ppm in 8 hours;
For the percentage drop over 24 hours: the FC went from 12 ppm to 8 ppm; so a drop of 33%
Later on in early October, after a line-flush, drain & refill, I took the FC to shock level and did another test.
The percentage drop over 24 hours: the FC went from 14ppm to 10ppm, so a drop of 28%.
From what I've read on this site, in the case of a covered spa, the percentage drop over 24 hours seems to be what is most relevant to monitor. This link on
24 hour demand may be of interest, if you haven't already seen it.
Hope this helps!
Ron
