Went out after Hurricane Matthew and now my Hayward SuperPump isn't working. When I flip the switch it starts humming but doesn't pump any water. If I leave the switch on long enough ~5-10 seconds the pump will stop making noise and start to smoke. I did some research and thought it must be the start capacitor so I swapped it out in no time. Flipped the switch and no change. I can spin the shaft and the impeller by hand and when I spin one the other one spins as well. Started looking a little closer and when its humming, the shaft is actually spinning (and not slowly). I'm now at a loss, any help is GREATLY APPRECIATED. Thanks.
