New Pool, Hose Filled. Super High Alk.
Added. 15,700 Gallons by calculation.
I've been using 8.25% Chlorine Bleach from Menards, But last year it was under $3/gal, this year it'ss $3.99/gallon. Onsale it's 2.94/gal. I called all the pool stores in town and found 1 that sells it in bulk, but it's $3.50 a gallon, though it's 12%. How much is the higher % worth? I have SWG, but it isn't up yet. So soon, I will not need to worry about buying chlorine!
-ThaChad
It is showing me 163oz which sounds better
That is 0 FC to 7 FC
Ok, you were going to 4 FC which is absolute minimum for your CYA
Alrighty.
Pool has been up about a week now, pool is clean, water is clear.
Current Water Specs:
FC - 10
CC - 1.5
PH - 6.8
TA - 120
CH - 60
CYA - 30
I got the SWG hooked up, but it is shut off at the moment. I added in 6 bags if 40lb pool salt today. I will check Salinity tomarrow.
I need to get the PH up, I turned the RJ up to the top of the water. Not sure how much that will bring up the PH.
I hope to start the SWG this week.
-ThaChad
