Is there such a device that will capture the heat generated by a homes central heat/air condenser and transfer that heat to the pool? Seems like if you could use the pool water to cool the outside condenser coil when the house air conditioner is running that would essentially be free heat since it is dissipating it to the outside air anyway.
