Still new to TFP but my pool has never been that clean. Thank you!
I will be traveling almost every week for work and I want to implement a liquid chlorine distribution system. I have a variable speed pump and will go with a Stenner pump (fixed speed). I already removed my old 320 chlorinator and will use the tee to feed the liquid chlorine (it felt good! bye bye CYA!). Now the question is how to connect the pump to my Jandy panel. I have 4 Aux already used (Air Blower, Spa Light, Pool Light, Polaris Cleaner) but there is one Aux that I am not using - the one for the Low Speed pump (which I don't need for my pump). I really hope there are some Jandy panel experts out there. Here are my questions:
1) Is it possible to re-purpose the "Low Speed" Aux to be used for the Stenner?
2) My Ecostar pump is 230V - does this mean that I should order the 220V Stenner?
My other option is to buy a separate timer but I really like the idea of the integrated setup because it saves me the purchase and ongoing setup of the separate timer, and I am 100% sure that the Stenner will only work when the pump is working.
Thanks!
Anthony
Thanks!
Anthony
