- May 21, 2008
- 216
- Vinyl
- Monarch ESC36 / ESC8000
My Waterway CHAMPS 115 pump motor after nine years is about on it last leg. Noise, whine....you know the drill. Looks like the replacement motor is the standard B2853, and is an easy cheap fix with a gokit. I would LIKE to go to a 2 speed motor. My timer is Intermatic PF1102MF digital. Both pump and Salt Generator run 220v on the same switch. Question...is there a direct replacement, 2 speed motor, and if so, can I use my existing timer?
As always, thanks so much in advance for all the expert assistance!! Looking forward to all responses!
Sami
Sami
