Russell,
Is there anywhere in Pool Logger that tells you what your ranges should be? For instance, I have a pH = 7.4 Pool logger states:
I cannot find where logger believes my pH level should equal 7.6 which is what the above calculates. And why is this a "Danger"?
Good call. It assumes TFP recommendations of 7.5-7.8, you can put in a single target for this but not a range that you want to stay in. Good point and, yes I need to modify it to show that and you are also right that it is not a danger when you are still in the range you are. I will work to remedy that.
Let me think on how to do this to modify for rangesNot only would I like to see the values that Logger is recommending, but also be able to put in the ranges I would like for those values. For example I can currently put in a Target pH = 7.4. But I would like to put in a Range of 7.4 - 7.8.
You can view entire history. Do you mean download to an excel file or something?*******
This project is coming along great and I appreciate you letting us be a part of it. Just a few items to make it my primary logger:
1. Ability to download all inputs with a single stroke (i.e., you have the ability to download one day at a time, but I would like to download my entire database of entries at one time).
On the list2. Tie Notes to a particular test. (I know this one is being worked)
3. Ability to set individual reminders for each test component.
Already working on this!4. Add ability to log what actions where taken due to the tests. For instance if it suggests that you should add 56 ounces of Bleach to raise to your target FC, then I should have a spot where I can enter in how much bleach I added. I use this to estimate how much the pool is costing me in bleach as well as getting an average of how much bleach is needed for certain times of the year.
Thank you. I love feedback like this. I want to keep making it better for everyone!The above are just suggestions and not criticisms. I think your project and work is awesome!
