- May 15, 2007
- 12
After pulling off the winter cover on AGP Vinyl 16' we found small leaks that sediment had entered water. Not big deal but vac to waste took care of most of it.
My pool store says TA range can be 125-160. When I first tested it it read 170.
I added another 4lbs Borax and adjusted pH down to 7.8. Trying to reduce TA some I added more acid and did some aeration and here are my readings. Is my pool store TA range too high?
Whats next. Water looks real good now.
FC 3.0
pH 7.4
TA 140
Temp 78
CYA ?? Just added 1lb hth brand
Borate Level 30 (using test strips)
FC 3.0
pH 7.4
TA 140
Temp 78
