waterbear said:
As far as bump filters... the DE gets dirty so you bump it off the grids to allow the dirt and DE to mix together and recoat the grids?!?!?!
You just coated your grids with dirty DE! You have NOT cleaned your filter!
To clean the filter you need to break it down.
Hey waterbear!
Just to clarify on this one...Bumping the DE filter for me is actually both a necessity and life/time/money saver. At least it is for my filter. I have the Hayward EC-65. I put DE in it at the beginning of the season. Anytime the water gets really dirty or has any kind of algae outbreak, the filter pressure will rise quickly. It will go from 12 to 25. Once at 25, the water flow from the return lines decreases tremendously...and it won't correct until you do something about it.
To fix this, all you gotta do is turn off the pump, bump the filter 4-6 times, turn the pump back on...and bam all is good...pressure back to 12 and water flow is great. Takes only 2 minutes tops. Now if you still have the algae outbreak or the dirty pool, the pressure will probably go back up again in about 24-48 hours, at which time you'll need to bump again. But once the water is back to normal, all is good again and the pressure won't rise until you have another issue.
I can actually go an entire season without changing the DE. Usually when opening to a really nasty pool, I change it 1 time once it looks good (just to give it a fresh start). Once your pool is looking good though, I usually end up bumping once a month and that's it. And my water is crystal clear.
The only alternative (that I'm aware of) would be to change the DE, which is kind of a pain, more time consuming, and would get expensive.
But anyway...in my experience, the point to bumping isn't to clean the filter...it's just to shake up the fingers inside so that it can start filtering again.
You may have had a different experience than me though...but for some, bumping has it's place
Oh...and thanks for all your help in these forums
