Thread: KH and GH questions.
    orthofish's Avatar
    Jan 2009
    Northern Middle Tn.
    562
    I have a test kit for my fish tanks that mesures KH(carbonate hardness) and GH(general hardness.)
    Is KH similar or the same as TA??
    Is GH similar or the same as TH(total hardness?)
    Lynn
    16x38 FG, 20,400G, 1HP/2sp Tristar pump, Hayward 425sq ft cart. filter, Pro Logic4, SWCG, 3 returns, 2 main drains, 1 skimmer, 4 Pentair deck jets, Hayward Phantom pressure cleaner/booster pump, TF-100 of course :-)orthofish-s-pool-build-finally-t13179.html
    Guest
    Re: KH and GH questions.
    kH is TA, for all practical purposes. Your kH test is actually testing TA (total alkalinity) and not just carbonate alkalinity. In a swimming pool the only other real contributor to the TA that might need to be taken into account is the CYA but only if the levels are very high, otherwise it's contribution to TA is negligible. In an aquarium the main contributor to the alkainity will be bicarbonates so kH and TA are,for all practical purposes, the same.
    GH is TH (the sum of calcium and magnesium hardness) and is a useless test for swimming pools. We are interested in Calcium hardness only (which is a common test in saltwater and reef aquaria.)
    orthofish's Avatar
    Jan 2009
    Northern Middle Tn.
    562
    Thanks Waterbear. That's what I thought.
    From here on out I will use TA, not KH.
    My tap water TA is only 3. That is somewhere between 0-50 ppm.
    My tap pH is 6.6 but outgasses to 7-7.2.
    So I will need to raise both of these with a fiberglass and SWG pool, yes??????
    The reason I'm asking is they are going to commence digging Saturday
    Trying to decide what I need to have on hand when I begin filling.
    Guess I better start by ordering my TF100 test kit
    Lynn
