A little water is leaking out of the inlet. I've tried to tighten it, but it won't tighten any more. Is there a seal or gasket? Would appreciate any advice I fixing.
Thanks
Thanks
Hello! I know your post is old but I’m now having the exact same issue you had. Did changing the o ring solve the problem? Also, when it was leaking, did it cause your pump pressure to go up? Thanks, KenA little water is leaking out of the inlet. I've tried to tighten it, but it won't tighten any more. Is there a seal or gasket? Would appreciate any advice I fixing.
Thanks
