I am in the middle of a home owner build of an 18x36 IG vinyl liner pool. I will be installing a pentair intellibrite 12v light in a pentair quick niche with an intermatic px300 transformer. My question is about running the conduit between the light niche and the transformer. The transformer will be mounted about three feet above the water level. Can I just run the conduit straight from the niche to the bottom of the transformer or does it need to go through a junction to prevent water from entering the transformer? If it is conduit straight from the niche to the transformer then do I need to put anything in either end of the conduit to prevent water from entering the transformer? Any help you can give is greatly appreciated.
Sent from my Nexus 6 using Tapatalk
