Two years in a row I have had a leak in my pool cleaner line. Have had to dig under concrete to repair the leak. Was told by leak detector guy I could close off this line and use another. This year I seemed to have the same problem and refuse to dig that hole again. Finally decided to close off that line. The line seems to run from cleaner booster pump, straight into the ground to the return in the pool where I connect the cleaner. I plugged the return in the pool and cut the PVC pipe going to my booster pump and plugged that.
it seemed to work the first couple of days but now have noticed I am losing water somewhere...not as much as before, but still a lot. Is there something I'm missing? This line doesn't seem to have any kind of valve unless it connects to another pipe under ground. Do you think I have closed this line properly and maybe have a leak somewhere else?
