This morning I got my FC up to 4 and my ph from 8.2 to 7.8 by following pool math. So I didn't get a chance to test it again earlier but did tonight. Here are my current numbers:
FC 1.5
CC possibly .5. I thought it was 0 at first but there was a slight pink tone (unless its just in my head from concentrating on the ph so much). I added one drop and then thought it went perfectly clear
PH 7.8
TA 120
CH 150
CYA.. I filled the tube and could still see the black dot. It was quite murky . Thought I was pretty close to not seeing it when I filled the cylinder
I tried to get stabilizer today but they store was out. Is this my issue? Because of the cya? Im putting in the last 2 lbs of acid for ph tonight and will add some dichlor according to pool math. The stabilizer would be why my fc drops?
FC 1.5
PH 7.8
TA 120
CH 150
