Your pool store should be able to test it for you. I'd take pool water and fill water to test.
JasonLion said:I would go with a shock level of 10 for now. With CYA that low you will lose a lot of chlorine during the day. A good measure of how much progress you are making is to measure how much FC you lose overnight.
Just wanted to congratulate you on the progress you've made so far.DamianS said:Sounds good! I did these checks just as the sun had gone down, I'll check again at sunrise. I'm gonna go scrub!JasonLion said:I would go with a shock level of 10 for now. With CYA that low you will lose a lot of chlorine during the day. A good measure of how much progress you are making is to measure how much FC you lose overnight.
Hi Casey! I probably wasn't clear, I was just joking in that first paragraph.Casey said:I can't say anything about the BioGuard but I do know it has nothing to do with the BBB system, even though it begins with a B. I don't think you need it and if you haven't used it, you should probably take it back. JMPO.
DamianS said:I'm thinking of putting her on Craig's List.
LOL!Cap said:DamianS said:I'm thinking of putting her on Craig's List.
Pics?? J/K
I am definitely going to post pics!Lershac said:MUST HAVE PICS OF CLEAN POOL! BEFORE AND AFTER PLEASE~
yes I am yelling.
