I got that impression from reading though this thread. Also, not mentioned but I am questioning for later....
I know this equipment is new to you and you are a little unfamiliar with it. But you say you have an "Aqualogic" panel. But you make no mention if you have a Salt water Generator. It is possible to have the AQL without salt, but generally salt is the main reason builders use that panel. If you do have salt, this will be important to know. Not now but later once you get into "maintenance" mode. It will change the way you do some things. Is there anything in your PVC lines that look something like this:
Maybe the original owner wanted the Aqualogic panel because it let him control everything from inside the house with this thing?
16,600 gallon, freeform, gunite and plaster pool/spa combo. Hayward SP3207EE pump, S310T sand filter, Century 1081 boost pump and Aqualogic panel.
