Max2k...thanks for the input. I installed and filled the pool myself with city water July of 2015. I had been skulking around the troublefreepool web site for several months before I made my purchase and did the install. My biggest fear was maintenance. My wife had wanted water in the backyard for years, but the thought of pool maintenance always gave me the heebie-jeebies. The methods espoused here gave me the confidence to pull the trigger and make the purchase.
Nothing has been in the pool but liquid chlorine, stabilizer, muriatic acid and a few tri-chlor pucks while we were away. I've also been a little obsessed with it being only me and my bride adding chemicals to the water. I think I just started to overdue the use of liquid chlorine. If 16 ppm is good (read recommended) for a SLAM at 40 CYA, then of course 24 ppm is better. I always stuck to the TFP philosophy regarding pool store chemicals.
I think, maybe, the high levels of chlorine (SLAM level ppm and above) for nearly three months jacked up my pools chemistry (specifically CYA). We shall see. Again, I can't tell you how much I appreciate the thought given to my predicament by you folks on the forum. You guys rock....
