davethomaspilot
Phizy,
I'd be very interested in following what you find.
I've have a new pool and maintained over six winter months using an ionizer, ozone injection, and a weekly dose of three scoops of powdered shock (yes, shock is chlorine). That's just what my pool builder setup for me and that was before I found this forum and started doing research.
I haven't had any staining or algae and crystal clear water, but I figure some chlorine to make sure the disinfectant level is adequate can't hurt. It doesn't take much to get significantly better protection than copper alone can provide, especially at 0 or low CYA. A little bit of copper also greatly increases the sanitation effect of FC.
I have an IntelliChem that doses chlorine to regulate ORP and acid to regulate PH. Before adding CYA, I'm going to monitor FC to see how much it varies in my pool during full sun days. At 0 CYA, the recommended minimum chlorine needed is based on a predicted decay rate of chlorine due to exposure to direct sunlight.
So, first I want to verify that. Shouldn't be hard to test give the VERY fast predicted decay of FC at 0 CYA using the FAS-DPD test.
Next, I want to see how much the FC decays with the IntelliChem actively regulating the ph and ORP. I'm thinking the TFP recommended minimum FC is based on having a buffer when only a single daily dose of chlorine is done, or maybe only a weekly dose. Might be different for a system that runs the pump and doses at frequently intervals during midday. Since their recommendations are for an "average" pool, average might exclude pools with automated dosers.
Just got the FAS-DPD kit yesterday and will start getting daily data. Please feel to email me with what you find out and I'll do like wise if you're interested in what I find out.
Good luck!
Good luck!
