Welcome to TFP and congrats on the test kit
Those numbers look great but you need to get some CYA in there (CYA of 30 recommended) (I take it this is a new fill), the HTH brand 100% granules from walmart work great, use poolmath to know exactly how much to stuff in a sock and put in the pool in front of a return.. you can need the sock as much as you want, once all CYA is dissolved test 24 hours later.
Your TA is a little high but as you drop your PH using MA your TA will also go down
