Howdy, Cloudy and rainy today, Cold snap moving through. Im so Happy I found TFP. We had our Viking Pool installed in October 2008, We do enjoy it.This past year I broke rank and file and closed the pool completely down, due to our winter travels, Didn't want to worry w/ freezing anything. I uncovered the pool, Spring is here, The water was Kermit the Frog GREEN, maybe Hulk Green....Yikes.
March the 28th,
Mon. Day I get everthing running, drop in 1lb of Shock (Sodium Dichloro-S-Triazinetrione Hydrate) w/ pump 24/7
Tue. Day 2 not a whole lot of difference, Pump 24/7. Start searching for help, found TFP.
Wed. Day 3 not a whole lot of difference, drop in 1lb of Shock, add water. Pump 24/7. Order Taylor K-2006 w/ Amazon Prime.
Thur. Day 4 Ooops forgot to turn off water, Pool full, 18" new water. Pump24/7 Flower beds Full, all is good. Water looks way better. Go to work
come home, Taylor K-2006 arrived, go out side water WAY Better, vacuum all debris and sent to "waste". Break out the Taylor.
Findings:
FC 12ppm, CC 14ppm, pH 7.4, TA 160ppm, CH 290ppm, CYA 62ppm, Sat Index 0.0-0.1
Okay TFP, Your the master, I'm the Grasshopper,
April 1,
Fri. Day 5, pump 24/7 rainy cold day.
What do I need to do NOW!!!
Thank You,
March the 28th,
Findings:
April 1,
Thank You,
