Thanks for those suggestions, though I'm feeling a bit over-whelmed!
I found SeaKlear Phosphate Remover MSDS and it says '25% to 65% lanthanum chloride hydrate'. Yep, the phosphate removers here provide the removal rate and dosages recommended and their usage sheets also recommend a clarifier used in conjunction. I compared with your rate (32 oz per 10K gals to remove 9000 ppb) and the product I'm looking at here (20% lanthanum chloride) shows a rate about 4 times higher. Before I found TFP, I used a bottle of lanthanum chloride phosphate remover without any drawbacks. I looked back at my notes and I used way more than needed - around triple. That said, I make a good guinea pig for glass vs. sand because one of the two pools is on conventional sand filtration.
Incidentally, I noticed a question earlier about what threshold might be indicated, in the event that we found that phosphate removers were cost-effective. I've read a lot of labels lately, and I've seen a range of 125 to 200 ppb as the threshold for treatment. I'm not mentioning this because I believe it's right; it's just chem co. numbers after all, probably pulled out of thin air, but maybe it gives us a rough indicator or starting point.
I'm concerned about test kit cost because I'd like to try a method that would be do-able for most people at a cost commensurate with the potential savings. We're OK with pool store tests for iron and copper, and I know their accuracy isn't great on those either. Do you think they're better, worse, or much the same at testing phosphates vs. iron and copper? I suppose all over the map, haha
So what are the risks of using too much lanthanum chloride? For example, I have two test results from different pool stores, both at 200 ppb. So I was thinking of adding enough lanthanum chloride to remove 500 ppb. That's quite affordable for me. I'd like to stick to a method that's easily available to average pool owners. If helpful, I could take water to a few more pool stores for the added entertainment! Like most pool owners, I have no call for chelates, so I don't have huge ongoing inputs of phosphates. Likely just fertilizer blow-in and a bit in the fill water contributing to what I'm seeing in pool store tests (after the 'Start-up Tech' contribution when the pool was first filled).
Alum floc is also easy to come by. I'll go look at some products and see if they have any instructions for a filter method. Whatever might be easy for an average pool owner is something I'd like to try. It seems that lanthanum chloride is the common, simple, easy to buy, method.
If there's an opportunity to save people money, even if it's years in the future, I think it's a worthwhile exploration. No one got to 7.5%/4.5% FC/CYA without looking at lots of results, but it had to start somewhere
