I had to run up to Leslie's for a pumice stone and when the guy I was talking to found out all I use is liquid chlorine he said he would strongly encourage me to stop using it because it is a dirty chlorine and increases the (TDS) Total Dissolved Solids in my water and would force me to use more chemicals to fix in the long run. Out of curiosity I then asked about the relationship between Cyanuric Acid and Chlorine he said there was none and he recommended keeping the chlorine between 4 and 5 until the CYA gets above 100 the drain and refill pool. Figured I'd share that with everyone.
