Hi
I had green and black spot algae so needed to SLAM
I've run out of dpd powder (taylors TF100 kit ) so bombed the pool with 20 litres of liquid chlorine for 2 days then 10 litres a day for 5 days. Algae is gone now hopefully. Cant do an overnight loss test.
Have had no chlorine in the pool for 3 days and SWG is turned off. The filter is still running.
I've used the drop chlorine test and it is a dark brown colour and I can still smell strong chlorine on my hands when feeling the water.
CYA is only reading at about 35 . Usually at 75 to 80
I was reading that the tests aren't that accurate at high chlorine rates.
We are having long hot days here at the moment so is my best option to stop any tests and let the sun bring down the FC . Should I bring up the CYA levels yet or will that make the FC take longer to dissipate?
Can I do my other tests yet ?
Thanks
brad
Thanks
brad
