Kimkats had just said I need to put plaster as my surface just above. Will get the change made next time I log on by computerIs your surface vinyl or other?
Sent from my DROID RAZR HD using Tapatalk
I keep thinking about your pool...
You trusted me on using the DiChlor which most TFPer's would tell you to avoid. Please consider adding the borax (20 Mule Team brand in the laundry aisle). I am concerned that your pH may be significantly lower than 6.8.
You could also use some distilled (and only distilled) water (recipe: 1 part distilled to 1 part pool water. Do not multiply your result) and do a pH test with that and see where you are.
