- May 26, 2010
- 299
- Vinyl
- CircuPool RJ-45
I am having some pool repairs done that require them digging up the lines. Right now my pool (18'x36' rectangle with 8ft deep end) has all 1.5" piping. After reading about Hydraulics, I am considering replacing it with 2" piping. Is there any problem with having a flow rate that is below the max velocity at 6ft/sec rate with 2" piping. ie., any issue by having "oversized" piping. Although, my gpm flow rate for turnover in 8hrs is about 56gpm. I have a 1hp pump. The pool people say go to 1.5 HP. Doesn't make sense after reading all the information. I will upsize my sand filter from S220T (52gpm) to S244T (62gpm). I am elimninating my main drain as well. Given all this, is it recommended I go 2" piping? and any issue with 60gpm flow rate through larger 2" pipe?
They were going to replace with 1.5". Now would be the time to upsize if it makes sense.
Thanks
Rich
Thanks
Rich
