Happy Thanksgiving everyone.
I have just moved into a new resident with a pool + spa attached and I've been doing some research on some basic pool operation. However, I am really stuck and would like the community's guidance.
Before even moving to how to clean and chemical balance of water, I think I need support in how to even operate the water. Ive attached a few picture of the pool and its filter operation. I think I've messed up a few times already because the water level is much lower compared to when I moved in.
There is a total of two Jandy Value that controls the pool and spa, there is no heater attached. Based on trial and error, I know that the 1st/top value controls water going to either the pool or spa. One side is spa and one side is pool.
The problem I have is with the bottom value, both left and right engage the filter, one side bring it up to 10 PSI? the other 20 PSI. However, I do not know the setting for waste, raise, backwash, filter.
Also, how do I raise the overall water level of the pool?
Thanks.
Thanks.
