First post, but I have learned lots from TFP over the last couple of years, so a belated thank you
I am in the process of redoing my pool deck, well the contractor building a covered patio is redoing the pool deck and I am watching
We are replacing a poured concrete deck with pavers. I bought liner track (HM2 Straight Sections Parts - INYOPools.com) and the paver guy installed it on top of the pool wall. I was a little surprised when I came home from work and saw how he had installed it. There are 3 corners like this. The "gap" between sections of the liner track is about 2 inches.
There is one corner like this
The pavers are going to be installed with a thinset over the concrete. I want to make sure that this liner track is not going to cause problems when the new liner is installed. The track was installed with self-tapping screws before the concrete was poured. I assume it would be easy to cut the heads of the screws off and then drill holes in the concrete if I need this redone.
Does anyone have any insights? Thanks.
