If it's calcium chloride do not pour it into the skimmer. Best to follow the package instructions....
waterbear said:Since calcium chloride generates a LOT of heat (which is why it is used to melt ice) when it dissolves I would predissolve it. When you broadcast it over the water it can fall on the liner and the generated heat would not be good. (Not so much an issue for plaster but I still don't recommend broadcasting.) Pouring it into the skimmer would be even worse, IMHO!
If you doubt the amount of heat just put some in a bucket of water and stir it with your hand! (Don't say I didn't tell you so when you are treating the burns! Well, perhaps that's a slight exaggerations--or is it? )
TizMe said:To late I broadcast it !! I made sure it went into the center of the pool well distributed ....
