Do high levels of CYA plus high levels of Chlorine promote metals from coming out of water solution, thus promote staining?
I ask because I "think" that's what the Pool Store told me after they tested my water. And I do have high levels of both. They definitely said High CYA...but I'm unsure if the High CL was the second part of the equation. Or perhaps the second part was referring to a different chemical level?
I guess what I'm asking is, does High CYA + a chemical (low or high) {whether CL or not} = promotion of metals coming out of solution/staining?
Thank you very much for your knowledge & help.
