Hi All
I'm currenty redoing all the pipe work on the pool. I have a quick question. If the return from the Multiport to the pool eye is of an angle to allow the water to drain out of the pipe into the pool when the pump is off, will that cause the remaining water to drain back via the filter and pump back to the pool causing it to have to prime the pump each time the pump is turned on, or will it be Ok and the water wont flow back.
I can change it easy now as I've yet to start that side of the plumbing, but dont want to over complicated it if I dont have to.
