Hi - I have a fiberglass pool leak and I can not find the leak. Any help would be greatly appreciated.
1. Leaks 6 inches per 12 hours if pool is running or not running. Doesn't matter, still leaks
2. No bubbles in lines, Pump stays primed when on and off.
3. Turned off the pump and allowed to drain. It drained below all jets and lights except the main drain. Where it stopped, I could NOT find a leak in the Fiberglass shell. The pump stayed primed.
What am I missing? Thank you!!!
