singingpond
The K2006 kit has enough CYA reagent to run half a dozen tests if I recall correctly - that should be plenty to get your baseline data. The reagents that people are telling you to get more of are the ones used in the high level chlorine test (FAS-DPD test), which you will need if you proceed with a SLAM.
When you run the CYA test you may find it hard to be sure where the test endpoint is reached; that is a common experience, as that particular test is more subjective than the other tests in the kit. To get more practice with the CYA test, without wasting reagents, pour the sample from the viewing tube back into the little dispensing bottle and just run the test again with the same sample. Some people find it useful to do this three or four times initially, to get more practice with the test procedure.
