About 3 weeks ago my pool started to do some weird things like the spa starting up in the middle of the night or the pool heater coming on by itself and the strangest was the valves changing position and started pumping out the hot tub to the pool.
I did the obvious checked to make sure there was no program in for anything that happened, checked with the neighbors to make sure we are not sharing a frequency for the remote. I just fired up the remote and turned off what ever was going on except for the valve issue I turned on the service mode on the controller and did a spa fill to get the valves sequenced again.
The pool is 2.5 years old so of course no warranty left for automation but before I go to the expense of changing a mother board I am curious if anyone has gone through something similar with an easy fix.
Thanks Steve
Thanks Steve
