I am wondering if anyone has done the following, and if so what 3-way valves they used. I need a t shape flow where one direction would would be full open and feed the inlet and both sides, a turn to the left would feed an inlet and the left side outlet, a turn to the right would feed the inlet and the outlet to the right. 180% would shut the valve off from the inlet. On the three way actuator the off position would actually be both outlets (opposite off). This would be mated to a dedicated feature pump so when it is off no water features would be engaged. I want to connect an easytouch to two such valves with actuators with the following configuration:
valve one:
position one inlet plus left (fountain)
position two inlet plus right (outlet to valve two)
position three both outlets (easytouch would think this is off but it is the opposite full open setting)
valve two
position one inlet from one plus left (bubbler)
position two inlet from one plus right (laminars)
position three inlet plus both outlets (if both are in this position all features would operate).
I think this would let me operate any single feature or combination of features. Has anyone done this or know if it would work? anyone know where to get valves that work this way? -Thanks
valve one:
valve two
