I am heating my pool for a party today. I turned it on last night at 2am. The outside temp is 60 and the pool water was about the same. I wanted to heat the pool to about 83.
Question, my Jandy LXI 4000 has a "pool heat" and "spa heat" button. I put it on "pool heat" and after 5 hours the water temp is now 73. If I push the "spa heat" button, does that give a faster heat or is it the same as "pool heat"?
I have manual valves so they are set to pool. Are both setting the same amount of heat?
