I was recently asked to look at a pool the forum helped me stabilize years ago.
1. The initial problem of why I was contacted was that there was a suction side air leak whenever the automatic pool vacuum (Barracuda MX-8) was connected to the skimmer. I changed the hoses and still got a leak. Then I tried hooking up 1 hose section at a time (this vacuum uses twist lock hoses). To my surprise, even with just 1 new hose 3 foot hose section fully primed with no air in it connected to the top skimmer, I would still get a large air leak in the pump basket. I would get no air leak when the top skimmer was just functioning as a normal top skimmer basket. Is the additional pressure caused by hooking up the vacuum hose causing the leak to appear?
It was time for a filter cleaning anyway, so I changed the grids and manifold (grids were well worn), changed the standpipe o-ring, changed the large filter o-ring, changed the pump basket o-ring, and tested every joint and plug by pouring running water over it with a hose. I couldn't find the air leak. Now I'm wondering if it's maybe a cracked skimmer pipe that only shows up when a vacuum hose is attached to it and there is additional load placed on the pump system?
I don't know if anyone has experienced anything similar, but any suggestions on where I might be able to trace this leak? I don't like running the pump too long in the air leak state as it will lose prime fairly quickly.
I've done a bucket test, and I don't seem to be losing any water. It just appears to be an air leak.
I resorted to just placing a basket in the top skimmer.
I was in the process of contacting a leak detection company.
2. I went to check the water balance.
The first test I got, the water was clear, but the numbers were way off.
FC 5
CC 0
pH 6.8? (It was below 7)
TA 10!
CH 1875!
CYA 30
Salt 3200
Temp 65
CSI -1.56!
When the forum helped me with this pool years ago, the CH was fairly high, but below 1000. Now it's solidly above 1000.
As far as I know, they were using liquid chlorine to chlorinate the pool. They floated pucks for 2 weeks prior to my arrival when they went on vacation.
From these results, I added about 10 pounds of baking soda with the goal of bringing total alkalinity to 50. For a 22K gallon pool I believe the calculation was for 16 total pounds of baking soda to reach TA 50. I'm glad I didn't do the full amount. I also added about 1/3 gallon of chlorine to try to bring FC to 6.
The second test 2 days later:
FC 7
CC 0
pH 7
TA 75
CH 1750!
CYA 30
Temp 67
CSI -0.18
The problem now is that I've got a cloudy pool. It's blue and I can see to the 3rd step in the shallow end but not the main drain in the deep end. It looks like baking soda hasn't dissolved or I'm getting calcium precipitating out. It appears that I overshot on the TA which makes me wonder if my pool volume calculation was off.
Any way to clear out this cloudiness?
I'm thinking this pool needs to be drained. I've struggled with this decision even years ago. I'm thinking of using an RO filter company. For a 20K gallon pool, they quoted me $1K for the job. I like the fact that most of the water will stay in the pool being that it is the hottest time of the year.
I'm not sure if this is better than just simply draining and refilling it?
3. Questions:
At this point, should I do the leak detection / repair first?
Is it even possible to do a leak detection in a partially clouded pool or should I try to wait and see if I can filter out all the precipitate?
Does anyone have experience with RO pool filtration versus draining/refilling the pool in the middle of July?
Thanks in advance!
FC 5
CC 0
TA 10!
CH 1875!
CYA 30
Salt 3200
Temp 65
CSI -1.56!
FC 7
CC 0
pH 7
TA 75
CH 1750!
CYA 30
Temp 67
CSI -0.18
3. Questions:
Thanks in advance!
