I just 'upgraded' my Intex pool filter to a stronger model which now has 1 outlet and 1 inlet.
My pool as 3 holes... One outlet, two inlet.
Now I have a problem. The remaining 1x outlet can either be plugged with the strainer plug (likely to leak), i would rather connect another outlet hose.
Here's my problem
I cannot find anywhere a Intex 1.5 hose T-joint. This is required in order to combine 2x 1.5 inch hoses into the filter. I looked online on Intex and there is nothing.
1. Should I keep searching? Is there any benefit to having 2x inlets with this larger 1500 gph sand filter pump I have?
2. or just fill it up and plug the remaining hole with the strainer hole plug? I guess I could also use a cork in the end to make it completely plugged.
Any thoughts are appreciated!!
Here's my problem
