Hi,
I accidently bought one (1) 12 ft SolarPoolSupply pannel that has a 2 inch header. My existing plumbing is 1.5 in. Will using 1.5 to 2 inch adapters cause any issues?
Not being a fluid dyn guy I'm imagining that since I have one pannel the water rate thru the pannel would slow and therefore heat accumulate more heat
I am also mounting it on my South facing fence sideways, manifolds on the left and right side of the panel (not top and bottom). Not being a fluid dyn guy I'm imagining that
My pump is 1 hp. and the lift is going to be 6 feet. The company said to
