I recently had my old pump (WhisperFlo) take a dump while restarting after Irma. It came with the house and is probably 10-14 years old. I decided to replace it instead of diagnosis. Thinking I'm smarter than I am, I just went off the fact that my backwash pipe is 1 1/2 and ordered a pump with the same HP as the old and 1 1/2" pipe spec. I just went outside to install the pump and found that the pool is plumbed with 2" pipe. Will using a pump with 1 1/2 in/out on a 2" system cause issues. I have a SWG, propane heater, and in-floor cleaning system attached.
Trying to see if I should keep this pump or go through the hassle of an exchange. TIA.
