Had an issue firing up the pump yesterday.
Took longer than usual to prime and then it was shooting air out the return in the pool.
Went to the room where the equipment is located and noticed the pressure reading on gauge was 0. Fired up pump... again taking much longer to prime, no reading on gauge at all.
Turned off pump, a load of air passed through and lost prime. Hissing sound coming from filter.
Set valve to back wash, fired up pump, took a while to get going however still no reading on gauge, water did pass through the little glass on filter though. Switched off, and it appeared to hold prime.
Had to leave it there as I was off out.
Questions:
Is there a chance the filter was clogged and the backwash has stirred the dirt and loosened things up a little?
Gauge was swapped out 2 years ago, faulty already?
Have ordered another gauge anyway, although I don't think it is that which is at fault.
Valve - Hayward Vari-Flo 711-13
Filter - Hayward S244T
Pump - Sta-Rite 5P1R
Questions:
