I have an existing aboveground pool. Oval shape, 34' L X 18'W, 4'D. (figure 18,300 gallons). I am throwing out most of the existing Hayward automation/equipment setup and replacing it with Pentair. I am planning to install an IntelliCenter with an IntelliChlor 40 SSG. I am planning to keep the existing Hayward H250DN gas heater and a Hayward SwimClear-C3030 filter. The pool has a single skimmer and a single return. Existing pipe diameter is 1.5".
I am trying to determine which variable speed Pentair pump is best for my application.
I read the IntelliFlo Wiki and Pentair's 2023 pump catalog. I am still not clear which exact model I need. According to the Wiki, only IntelliFlo and IntelliPro pumps work with Intellicenter. Still, there are multiple options - Intelliflo vs IntelliPro, diffent models, etc. Furthermore, all the IntelliFlo and Intellipro pumps seem to be rated at 3HP or more, which is probably a lot more than I will ever need for my pool. My wish list is as follows:
- I generally run my pool pump at the absolute lowest speed 24/7 and want the automation system to temporarily increase the pump speed when certain flow rates are required by the SSG or the heater
- I want the most energy efficient / cheaper to operate pump that is required for my pool size
