Here is a thread that was started to share different plaster colors. LIke @ajw22 says it is going to look a LOT different in water. It is going to be very pretty.
I love that waterline tile. I will also tell you that you will want to go through the tile boxes when they get there to pick through them. Each one may be different. Some will be prettier that the others. Some might be quite as pretty. You want the extra pretty ones on the wall where your eyes fall as you walk out to the pool for the wow factor. The not so pretty ones can be used for smaller pieces or inside the skimmer opening.
